Automatic Lighting Scenes
How do I set my outdoor permanent lights to come on and use a particular lighting scene instead of just one colour?
Commenting because i have the same question. Cant seem to figure it out.
From this screen, click on “Rules” on top.  Add new rule to turn on the lights.  Add second rule to turn them off.
I’m new also, so there may be a better way…but I select a scene in my favorites to open up and play now.  When I close app, that is the one that opens the next time the rule turns them on.
Please try the following steps:
1. On the Home interface, click on “Rule,” then tap the “+” icon in the top right corner.
2. Click “Schedule”.
3. Enter a name for the schedule.
4. Choose the start time.
5. Set the desired repeat options.
6. Click “+” to select a device.
7. Select an action. If you select “turn on”, it will turn on with the last used lighting effect/pattern.
8. Click “Save”, the schedule is saved now.
It worked, just plays the last chosen scene. Thanks
