I have 3 sets all in a group. It is scheduled to come on and go off at certain times. Which works correctly.
But the light favorite, christmas design, will not come on when they come on automatically.
Am I missing something the the schedule setup? I looked and cannot find anything to fix this.
Since our smart lights can remember the last used pattern, there is a way to set the schedule you want, here are steps:
1. Select and apply the pattern you want.
7. Click "+" to select the light.
8. Select "turn on". This means the device will turn on with the last used pattern.
Thanks. I’ll give that a shot.
Seems the app could be streamlined some as to not have to do all those steps. Or just add option to pick pattern under actual scheduling section.
I have the same issue I have tried the Rules but it will not let me set up the custom colors or pick one I have setup in each of the settings. I can select the custom settings when setting up groups but not rules. So it doesn’t remember the settings and you have to turn them on every night to the correct lighting mode.
Any suggestions would be appreciated this can be frustrating.
I agree with others the group setting should be all you need to do. To many sets to make them work. It would also me great for predesigns too for different holidays.
Felecia.
Dear Felecia,
The Rules and Schedule function is currently being improved and will be upgraded soon.
For now to schedule the lights to turn on with a specific light pattern, please follow these steps:
1. Select and apply the light pattern you want.
8. Select "turn on". This means the device will turn on with the last used pattern (which is the light pattern you selected in step 1).
