Make the B1 bulbs compatible with 5g wifi otherwise its just useless nobody uses 2g anymore, i have to buy a router and then it will work?? No ones doing that
Thank you for taking time to share your thoughts about our products. We are sorry for any inconvenience this issue may cause.
We have forwarded your feedback to relevant team for future improvements.
Currently, pairing the lights with Lepro app requires a 2.4GHz network connection.
Please consult your network/router provider on how to set up a 2.4GHz network first. After successful pairing, you may then enable the 5GHz network.
Alternatively, you can use the Bluetooth-only pairing mode, which allows you to skip the Wi-Fi setup step during configuration.
Taylor
