When using timer mode, why do the lights turn on default white? Regardless of the last mode used…
Since our smart lights can remember the last used pattern, there is a way to set the schedule you want, here are steps:
1. Select and apply the pattern you want.
7. Click "+" to select the permanent light.
8. Select "turn on". This means the device will turn on with the last used pattern.
If you have any questions or need further assistance, please feel free to reach out.
