Schedule doesn’t work
When I try to set a schedule, I set the time save it and after when I open the schedule time is not there, just day. Please help
Hi there,
Please try the following steps to create a new schedule to test:
1. On the Home interface, click on "Rule" then tap the "+" icon in the top right corner.
2. Click "Schedule".
3. Enter a name for the schedule.
4. Choose the start time.
5. Set the desired repeat options.
6. Click "+" to select a device.
7. Select an action. If you select "turn on", it will turn on with the last used lighting effect/pattern.
8. Click "Save", the schedule is saved now and you can see it on the ''Rule'' interface
