Need the ability to setup 2 scenes and make them switch back and forth at a certain speed or transition.
Thinking from other smart home apps that use shortcuts or scenes, on suggestion to achieve this might be to add time delays and the ability to activate a shortcut from another shortcut, schedule, or rule.
I agree with you that having scenes switch between each other is a great way to move from one part of the day to the next. For example, the lights flash a gentle breathing pattern as you are getting ready for work, then automatically shift to a work mode focus yellow by the time you start working from home.
While you could arguably do something with schedules, you’d have to set up a new schedule for each scene shift, and by the exact time of day, too.
Unfortunately we only support the selection of monochromatic light effects in the schedule function curently.
Please kindly note the lights will remember the last pattern and it will show the same effect the next time be turned on.
We have also forwarded your feedback to the relevant team for future product improvement.
Best regardsLepro Customer Service Team
