Alexa Integration
The Alexa integration for your devices is quite weak, I only purchased the light strips as they worked in segments and were Alexa compatible, however it seems the segment usage is only available on the Lepro app. Even saved styles are not available for use on the Alexa app, please can this be looked into as I would much prefer to be able to use the segmentation / light styling rather than one solid colour and this needs to be possible via voice control on smart home devices.
Thank you for your feedback.
Our smart lights can remember the last used setting, so after selecting your desired light effect, it will maintain that effect when you use Alexa to turn them on or off.
We've also forwarded your feedback to our technical team for further improvements in compatibility with Alexa.
I too was going to say the same thing. If I want the RGB/Rainbow effect I need to manually go into the Leopro app and switch to this because if I set my room to blue only using Alexa, I am then unable to ask Alexa to change it back to the Rainbow effect when I want.
We appreciate your feedback and will pass it along to our team for future improvements.
The Lepro app features an integrated voice assistant powered by LightGPM, which quickly analyzes your commands to control your lights. Please note that LightGPM is currently compatible only with the Lepro app. If you're using Alexa, Google Assistant, or other smart speakers, they will only recognize basic commands, not the advanced features offered by LightGPM. To activate sequential lighting and more complex commands, please use the Lepro app.
For more information on our Lepro AI features, please refer to instruction on our official website: https://www.lepro.com/ai-lighting-algorithm.html
