B1 bulbs won't won't in Alexa routines
Have some routines to turn lights on at certain times etc. Old bulbs worked perfectly, but new B1s do not. They respond to voice commands directly to the Echo, or in the app, but not as part of a routine. Have the Lepro+ app, and skill on Alexa.
Any ideas.
Thank you for your feedback.
We have forwarded it to our technical team to enhance the integration between the Lepro app and the Alexa routine. In the meantime, you might also try our Schedule function in the Lepro app.
If you have any further questions, please don't hesitate to reach out.
Hi, same problem for me. Ive just purchased 2xBP1 and 2xB1 bulbs from amazon.
Syncing was great and they respond individually. However, when set in a routine together to turn on, they do not turn on together. If you have a routine set for turning the lights off though, that works.
Same problem here. Alexa routines won’t work . Is there a fix for it?
Same problem, can trigger them by voice, but not able to get them to work in routines
