B1 Light issue
I have a few b1 lights. All connected fine. Then my son switched the light off at the wall. When it switched back on it wasn’t connected to the WiFi.
I’ve tried everything I can think of to get it back on, including putting another light bulb in but it won’t do it. Any other one connects absolutely fine.
I even fully turned off 5g incase that was affecting it and still nothing. Please help
1. Please switch the lights off and on four times to reset them breathing blue light and re-pair them to Lepro app.
2. Open Lepro App, click "Add device"
4. If it shows on top "1 Device Detected", then directly click "Check"
5. You will be requested to fill the name and password of your WiFi
6. Click "Next", the bulb will be paired successfully in seconds, and the bulb will turn to solid white color
7. Rename the bulb and click "Done"
8. Then you will be directed to Home screen of Lepro App and there you can see them in device list.
