B2 light bulb
trying to set up my b2 light bulb  its asking me in the app if my light bulb is flashing blue which it is but when i go to click yes it just stays on the same page and doesn’t let me set it up or go past that point i have had this light bulb set up perfectly fine before on the old app ever since the old app has been removed i been having nothing but issues with this “new version”.  i been having issues re setting up all my light bulbs for my house for years he used these light bulb for every light in my house ever since the old app got removed on the 5th i been having no light or have of them stuck on one colour how can i fix this !
Please note that the older bulbs are compatible with both the LampUX and Smart Life apps, while the new bulbs (such as the B2 bulbs) are only compatible with the Lepro app.
Based on your description, it seems you may be using older bulbs that were compatible with the LampUX app. We recommend connecting these old bulbs using the Smart Life app.
For the new B2 bulbs, please follow these steps to connect them to the Lepro app:
1. Turn on "Bluetooth", connect your phone to 2.4G WiFi
2. Turn on the light; it will start flashing blue light slowly, indicating that it's in pairing mode. If the light does not flash blue, switch it off and on four times.
3. Open Lepro App, click "Add device"
4. If it shows "1 Device Detected" at the top, click "Check"
6. Click "Next." The light will pair successfully within seconds and turn to solid white.
7. Rename it and click "Done"
If you encounter any issues during the connection process, please let us know which step didn't work so we can assist you further.
Feel free to reach out with any questions
