Connecting to wifi
Trying to add a B1 bulb.
Get to the connect bit and it takes me to wifi but im not sure what to do from there?? There is no Lepro to connect to?
It seems that one of the steps may not have been followed correctly. Please follow these steps to connect to the B1 bulb:
1. Turn on "Bluetooth", connect your phone to 2.4G WiFi
2. Turn on the light; it will start flashing a slow blue light, indicating that it's in pairing mode. If the light does not flash blue, switch it off and on four times.
3. Open Lepro App, click "Add device"
4. If it shows "1 Device Detected" at the top, click "Check"
6. Click "Next." The light will pair successfully within seconds and turn to solid white.
7. Rename it and click "Done"
If the connection fails, please let us know which step did not work so we can assist you further.
I have the same problem, I’ve tried turning the light on and off 4 times but can’t get it to go blue. I’ve tried so many times.
We sincerely apologize for any inconvenience this issue may have caused. We have sent you a direct message to provide further assistance.
