How to schedule lights to go back to fav colors
I have a custom fav color setting from 5:30-10:30 then schedule to go to warm white. There is no setting to have it come back on with custom colors
Please try the following steps to create a schedule to turn on/off the lights:
1. On the Home interface, click on “Rule,” then tap the “+” icon in the top right corner.
2. Click “Schedule”.
3. Enter a name for the schedule.
4. Choose the start time.
5. Set the desired repeat options.
6. Click “+” to select a device.
7. Select an action. If you select “turn on”, it will turn on with the last used lighting effect/pattern.
8. Click “Save”, the schedule is saved now.
This doesn’t appear to work on ours. I’ve tried it three times now and only white turns on. Not the Christmas pattern we had set.
Please note the Wake up/Wind down lighting effects are default settings.
If you want it to show a specific pattern at the scheduled time, please select this pattern and turn off the lights before the schedule timing.
Please ensure you have disabled the other settings for the same lights.
