How can you make a rule for your string lights to have a particular saved light effect or light pattern of my choice , to turn on everyday as a schedule? Like when i set ‘ON’ schedule for 6 PM everyday , it turns on as simple white light without any effect.
Please kindly note the lights will remember the last pattern and it will show the same effect the next time be turned on.
I have set up a schedule for on & off successfully. But this year it turns on correctly but the turn off is early by more than an hour. I tried changing the turn off to a later time but it did not change anything.
I’m thinking that I need to delete this schedule and start over but I don’t know how to do that. If that is what will resolve the problem
