Thank you for reaching out to us.
It seems like you probably chose the Wake up& Sleep function instead.
To make the light on at the certain time with certain color, please use the Schedule function, the guide is as below.
7. Select an action. If you select "turn on", it will turn on with the last used lighting effect/pattern.You need to set up separate rules to turn the lights on or off.
Regards,
