Lights go back to white every day
I have two sets of lepro lights on my building. I set them to a Christmas theme and I set the time which they come on and go off but every day when they come on they just are the default on solid white I go in and set them to what I want it to be and it will do it for that day and then the next day goes back to white again what am I doing wrong? How do I permanently set a particular theme so every day they will come on and go off with the correct lighting theme?
Thanks for reaching out to us.
After checking your device log, we noticed that you set ‘Wind down’ and ‘Wake up’ function in the setting of this light which was the reason to cause this situation.
Please kindly turn off ‘Wind down’ and ‘Wake up’ function and use Schedule function instead to set the light on or off or different colors with the certain time you want. Steps are as below.
1. On the Home interface, click on “Rule,” then tap the “+” icon in the top right corner.
2. Click “Schedule”.
6. Click “+” to select a device.
7. Select an action. If you select “turn on”, it will turn on with the last used lighting effect/pattern.
8. Click “Save”, the schedule is saved now.
Regards,
