I managed to get my lamp to slowly dim over the span of 20 minutes from the colour it was before the dimming starts. And now it suddenly turns from purple to this normal bright light and then starts to get dimmer over the 20 minutes. This is immensely annoying and I wanted to ask if anyone had a similar problem and found a solution to it. ^^
The Wake Up and Wind Down settings settings use default light patterns and cannot be changed. For the Wind Down setting, you can adjust the Initial Brightness from 0% to 100%. Setting a higher Initial Brightness will start with a bright light and then gradually dim it.
We apologize for any inconvenience and we will forward your feedback to the relevant team for future improvement.
Feel free to reach out if you need further assistance.
Ok great thank you. It’s just a little weird because it actually worked like I described before the latest update. So hopefully you will be able to restore or possibly add that function in the future. ^^
Thank you for your feedback.
We have forwarded it to the relevant team for future improvements.
If you have any further questions, please don't hesitate to reach out.
