I plugged the lights in. They’re all turned on and after 5 mins, while I downloaded the app, I heard a click and they turned off.
When I went to pair them the app says to reset by holding the only button down for 5 seconds.
This didn’t work. I tried sister, longer, unplugging and waiting. Nothing works.
Anyone able to help?
Hey there
After you hold down the button for 5 seconds, did the light start flashing blue? If it did, that means it’s in pairing mode and ready to connect. Try these steps:
1. Make sure your Bluetooth is on and connect your phone to 2.4G WiFi.
2. Turn on the light; it should start flashing a slow blue light. If it doesn't, just hold the button for over 5 seconds.
3. Open the Lepro App and tap “Add device”.
4. If you see “1 Device Detected” at the top, click “Check”.
5. Enter your WiFi network name and password.
6. Hit “Next.” The light should pair within seconds and turn solid white.
7. Finally, rename it if you want and click “Done.”
Let me know if that helps.
Please contact me, nothing works, device detected but no pairing
