When the string lights come on, they revert back to all white, how do you set them so it keeps the template i set them to, to come on as the same and not revert back to just all white?
Please try the following steps to create a schedule to turn on the lights if you want them to light up with the pattern you set:
1. On the Home interface, click on “Rule,” then tap the “+” icon in the top right corner.
2. Click “Schedule”.
6. Click “+” to select a device.
7. Select an action. If you select “turn on”, it will turn on with the last used lighting effect/pattern.
8. Click “Save”, the schedule is saved now.
