Is there a way to set the wake up alarm to blinking lights? I know you can change the color of the light when it turns on but is there a way for the color to change or to add more effects specifically blinking lights? Could this be a new feature in the app soon?
Currently, the light effects in the wake-up function are fixed and cannot be changed. If you would like your light to turn on with a specific effect at a specific time, we recommend using the Schedule function.
Here are steps to create a schedule:
1. On the Home interface, click on “Rule”, then tap the “+” icon in the top right corner.
2. Click “Schedule”.
6. Click “+” to select a device.
7. Select an action. If you select “turn on”, it will turn on with the last used light effect.
8. Click “Save”, the schedule is saved now. Please do not change to other colors or patterns before the scheduled time, otherwise it will turn on with the last used pattern.
We will also forward your feedback to the relevant team for future improvements. Feel free to reach out if you have any questions.
