When I program my lights to come on at a certain time (Wake up) they only come up on white instead of my previously set colors. So I go to my favorites, the selection is highlighted, but I have to tap it again to get my color scheme to come on.
I see that my question has been addressed in another users answer.
The wake up function appears to be mostly useless if you cannot use it with your selected colors. So Every Night I need to select my saved program? Or just turn them on & off manually ?
That’s not what I’d call Smart operation.
with google home (gen2. Hub) and the lepro app connected is my timeplan good working, i have only used the b1 or b2 lamps.
There is a way to set the schedule you want, here are steps:
1. Select and apply the pattern you want.
7. Click "+" to select the light.
8. Select "turn on". This means the device will turn on with the last used pattern.
Thank you for the support. The lights come on with my color scheme perfectly. It did take a quick minute to figure that I had to have 2nd schedule to turn the lights off. I like the fact that I can change to another pattern at any time and they will continue to turn on & off as scheduled.
